What is the connector in the pic that is not connected do? In this pic, on the tube, is a single wire connector. On my car, the unused connector is connected to a sensor on the tube. Can someone explain what these connectors are for, why one is not used, and if it makes a difference which connector is used. Hope this made since, it is late!
The single wire and sensor is for the temp gauge. Not sure on the unused connector.
where is your temp sensor for the PCM. that sure looks a lot like the connector for it.
If Gray/Red and Light Green/Red it is the connector for the ECT which should be just to the left of the gauge sending unit.
The other plug is for a temp sensor if you had a digital cluster. the single wire plug is for the temp sensor with an analog gauge cluster.
