1996 Thunderbird LX
This flew out to the ground in the accident I had. I got my car running so now I am moving on. Can someone tell me what this is and where it goes?
1996 Thunderbird LX
I have the vacuum line that comes of the engine go straight to the brake booster for now. I need to go install the cowl first so this gets put back together properly. I finally have time again so I can do all of this right.
Yeah but that connects to your PCV valve .. The PCV connects to the metal line near the airbox that runs down to that canister / purge solenoid ..
1994 Cougar XR7 DOHC/5-Speed
There are 4 vacuum ports off the engine on 96-97s, all on the plenum. The top one on that goes to the tee/booster, the two on the front that go to the PCV valve and EGR lines respectively and one on the back that goes to the charcoal canister. The booster line is unrelated to this one
1996 Thunderbird LX
42071
So this is not the only vacuum line off the engine? I know it goes to a tee on the wiper linkage. That is also off the car right now.
Oh.... well I feel like a doofus. Thanks for the help.
No Problem; the last time I can remember someone asking this question it was way worse...
  • Like
Reactions: XR7-4.6
