Any reccomendations on brands of gasket sealant? Anything special for the aluminum block and heads? I bought ARP studs for the heads, and I'd hate to blow a head gasket, and have to pull the motor for that. ;)
Refrigerator Raider Hater
Modulars use Multi layer steel gaskets. thunderferret is correct, no sealant is used. The heads and block must be VERY clean and VERY smooth, IIRC, the spec is <20uA.
Wow, glad I asked. I was going to buy a can of permatek spray...guess I won't be doing that.
So is that the same with the manifold gaskets?
Also, does somebody have a pic of a PI intake manifold w/aluminum crossover that is tapped for the temp sensors?
much appreciated
