I have a puller set meant for power steering and alternator pulleys but what kind of puller takes of the big crank pulley on an SC, Can I rent it at autozone?
well its a pulley with 2 belts running through it and yeah I guess I should have to just ask for the harmonic balancer pulley. Thanks for the reply.
thats pretty much what I saw in the ford manual but thats also an even better picture thanks.
I bought mine its not a bad price and plus will remove the steering wheel. Forgot what I paid though.
Your question still is not clear..
Are you ultimately trying to remove the Crank Pully, or the harmonic balancer?..
If you are just removing the pully, as it was stated it's only 4 bolts and the pully will come off the Harmonic Balancer..
If you Ultimately need the Harmonic balancer off, you will need the puller set.
Karl
