1 - 12 of 12 Posts
I took the foglights off of my '93 and put them on my '95. They bolted right in perfectly. I don't want to mess around with trying to pull wires through my dash and into the center console. That leaves me with the option of using a relay to have them come on with my headlights or running lights.
I am not an electrician, but I do have some wiring skills. I looked at Radio Shack and they listed many different relays. Which one do I need?
02 Explorer Pioneer
I would think any relay that can handle the current load of the two foglights would be fine. You probably want one that is weather proof. Actually I just bought an SC foglight switch for my center console and I have some lights so I need to research this too. I assume the SC uses a relay or does the SC light switch have enough capacity to handle the full load?
Timb - wire the fogs using a separate switch and a relay. A 30 amp relay for automotive application would be ok, but a 40 amp would be better in case you ever want to go with higher wattage bulbs. You assume too much from the Ford engineers. The stock headlight and multi-function switch will not handle the amps of the fogs added to the headlights. Those switches WILL fail sooner or later causing the headlights to go out or flash on and off which will be the result of burned up headlight or multi-function switch, or both. There is plenty of information about this problem, do a search for headlight problems or flashing headlights. John
Definately go wiith a seperate circuit. Dont take the chance with the stock setup or you will be replacing the multi-function switch. It may seem like like more work to run the wires through the dash. But its really simple, mine run from the battery, to a switch, took less than an hour. If you want to keep an original look inside, mount the switch to the plastic under the steering column. Thats were mine is and you cant see it, except at night since the switch has a red light to show they are on.
That's the whole reason I am going to use a relay. It is my understanding that if you use a relay, it doesn't actually draw voltage from the circuit, but only uses it as a signal to turn on/off another (seperate) circuit. Am I wrong?
02 Explorer Pioneer
You are right. It will draw it from wherever you feed it from. Most do it from the battery but you would be wise to put a fuseable link between the relay and the battery
Your right, my bad just been a long day. Use a fusible link like timb said. But I would still suggest not using the multi-function switch to run them. These things are iffy with just the stock setup.
Right. I plan on bypassing the multi-function switch completely. Hence, the need for a relay.
Ok I thought you meant you were gonna use the that switch to control them. You got the right idea on how to do this.
Discussion Starter #10 (Edited)
Okay, so here is what I have. The black represents the schematic on the back of the relay package. The blue represents what I think I need to do to wire it up. Am I right?
All bow down to my awesome photoshop skills, bwah-ah-ah. :)
Anybody know which wire to hook #86 to if I use the parking lights? I don't want my foglamps to blink when I turn on my blinker.
Also, I guess I need to add a fuse. It should go before the relay, in "12V IN" right?
Looks like a good setup. Similar to what I have except I have a seperate switch. Yep, the fuse between the battery and the relay. As for the wire for the parking lamps Im not sure off hand but somebody will know.
A 30 amp relay is plenty for 2 100 watt driving lights and is readily available at radio shack. I have run this setup in my 95 for 4 years now with zero problems.
1 - 12 of 12 Posts
