1 - 12 of 12 Posts
I'm having a crappy day I moved the car in the back of the house cant find half o my rtchet set anyone know xactly what size the ratchet is for that?
boy, are you in the wrong forum :) 15 or 16mm. try 16 first.
Dude I'm having one of those days
thanks
this belongs in the general tech section
The car fell off of the ramps
I cant find half of my ratchet set
and I cant get the damn drain plug off and I'm the only one who changes the oil !
not to mention I'm still hurting from my injury at work and I have to go back to work on friday wh ich will make it worse ( not that working under the car helps though)
chris, use vise grips to get the plug off if its rounded off. pick up a new plug at autozone, and a socket to fit that plug.
So, how did it fall off the ramps, did they collapse, it what happened? I use ramps for all my cars if possible (for oil changes, and anything that doesn't require the wheels to come off) and I am a fan of them over jackstands when possible.
stupid me wasnt paying attention all my fault on the ramp thing i drove up too far - duh
The bolt is rounded off, and the vise grips didnt help or any other wrench ...
Its wierd cause I always change the oil myself
cool beans thanks
Here's the latest just got back from the shop they charged me $20 to get the plug out and change the oil and filter and grease the front end
the said the car needs the upper ball joints and a serpentine belt soon but every thing else looks good
doofus is right, we have plastic tanks. glad you got the plug out. be sure to use the right tools :)
what a pain glad it s all done
I figure I got the oil and filter for free (giftcard)
and the oil change and for them to remove the plug was $20
so I guess I sort of broke even
I still cant believe I had to go through that much stress
1 - 12 of 12 Posts
