On Probation
I know that I will need a spacer for the lincoln LS Spare I need to know what thickness of a spacer I will need.
Have you tried test fitting it if you have it? With it being pretty narrow, it is possible that a spacer is NOT needed like is needed with a fill sized LS/new age TBird wheel.
On Probation
The wheel needs spacers to keep the lug nuts from bottoming and the wheel not being tight to the hub.
On Probation
I found out that I did not need a spacer. The lug nut that you need are door man part numbers 611-226 for plain short lugs or 611-229 for the stainless steel covered short lugs. f
i posted that to your other thread a month ago didn't i?
