1 - 20 of 28 Posts
My roommate is thinking about getting a 5.0 Bird and just wanted to know what to look for.
What was the best year for the 5.0 in the birds?
How easy is it to build up?
Whats the diffrence between the Mustang and T-bird 5.0?
If you guys can think of anymore questions I should of asked fell free to fill me in.
Thanks for the help!:D
All the 91-93 5.0's are pretty similar. The 93 has a different cam, but that is about it. They are very similar to the 94-95 Mustang engines, with different exhaust. You really have to watch it though when you go to buy parts because some are 94-95 style (intake), while some are fox body style (FPR).
That being said, I would look for a sport model. They have a stiffer suspension.
John
Definitely check for the Sport model, but also look for a lower mileage car.
The engine is pretty easy to build up. Your friend can use a lot from the Mustang engine, but the only things I know of that he cannot use are headers and any exhaust system.
OOOhhh... He might want to get a 92+ model because the gas tank was moved allowing for easier exhaust modification. My 91 is a ***** to mess with underneath. :)
Definatley get a 92 or 93 5.0. The 91s gas tank is a pain in the ***, and you'll want to get custom true dual exhaust.
get a 91 or 92
The 91 and 92 models had Forged internals where as the 93 did not. I have a 91 and even though the tank is a pain, I have a custom dual exhaust and it sounds sweet. If you want to run big mods get the 92 or even settle for a 91.
Don't forget that the 93 has the newer front suspension. The 92 is the way to go if you are not worried about having the older style front suspension. The older front end can handle a slightly wider tire without rubbing anyway. If your friend doesn't plan on building it up much than the 93 is fine. But, if he wants to spray or supercharge on the stock pistons, he should get the 92 'cause of the forged pistons.
Like most other guys said. I'd get the 93 I think it looks better, but you sacrifice the fordged internals, but you get the suspension. It all depends on whatr you plan on doing with the car. I'd go for a SC myself...........wait.......I did get the SC.
Probably the 92 sport gets you the most. Basically the only thing you don't get with that is the newer front spindles. Otherwise, you get the forged pistons, sport suspension, newer gas tank, etc. That's what I'd go with. Oh wait, that's what I did go with!!
John
Yes, 91's should have them
Ford used TRW forged pistons up until the end of the 92 model year in the 5.0's.
John
The '91's did, most of the '92's I believe (but not all of them) and I don't think any of the '93's did.
Since I got a '91 I'm making it into the 'Bird I want it to be. I've got newer style spindles sitting out in my garage, as well as the newer gas tank, 94/95 front end/hood (going to a '97 hood though with '97 headlights), and I'm also upgrading to a 4R70W, so trying to get the best of all areas in my opinion. Oh ya and SuperCoupe interior. :)
blownmerc!!!
I happen to own a 91'302. I have a nitrous express system on my mind in the near future.
I guess in my opinion i have a little bit better setup with the forged pistons.
It pretty much is up to you on which one to get, meaning ur modding episode...
8astang .02 cents
if you are looking for something that you DONT want... look for oil on the bottom of the tranny.... if you see oil, it needs a rear main seal and thats a pain cus the tranny has to come out.
1 - 20 of 28 Posts
