will the lights and radio, hvac and the starter work? im going carbed and would like to mount my msd in that space
The only "feature" that could possibly be affected is the A/C, but I am nearly certain that the computer only controls if the A/C gets cut off (because of WOT) and that the signal will still pass through to the A/C clutch relay. Obviously you will lose functionality of the electric fan and the fuel pump will not activate at all, but both of these can be solved by using the right temperature switch and wiring a switched 12V source to the trigger of the fuel pump relay.
yeah i cant use the stock tank and pump anyway and the fan will be cake
