1 - 19 of 19 Posts
dont get an engine out of a mustang. it will only cost you more money. get a 02-04 explorer engine. it will be about half the price for a better engine.
Jace041079 said:
But when you buy the gt engine you get the hp. Insted of getting the hp of an explorer and beffing it up. What would be smart money??
02-05 explorer motors are no different than a mustang, actually better.
The Explorer motors have the same heads, cams, intakes, etc. as the GT engine. Plus it has an aluminum block.
do the stang motors have aluminum block?
Fry Rice Specialist
crown vic and gm motor is about half the price of explorer motor.
explorer motor is the same from heads down as mustang except it has aluminum block which is better
the intake is not good though, it's a pi intake but it takes coolant from the front crossover to go to the heater core and in high performance use the rear cylinders get a little too warm
cliff's: get explorer motor but use mustang coolant mod'd intake
Or just get an explorer motor and use a Mustang Intake, or other PI intake. They're getting pretty inexpensive now (heck, even I got one and I'm notoriously cheap!)
there are three different explorer intake manifolds, two of the incarnations have a front nipple, one has a rear nipple.
If you do decide to go with a Mustang engine, stick with the '99-'04 and swap over your T-Bird ignition components and return style fuel rails. Theres a big horsepower advantage to going with the PI hardware over the NPI. You should really have the ECU retuned for best results though. :)
I wouldn't think so anymore. The Explorer having an aluminum block crazy has hit a lot of the local wrecking yards around here and they're starting to ask top dollar for the EX engines. :(
coggonobrien said:
the 96-98 cobra is pretty much a mark vIII motor so yeah. if you wanna talk the sc variations i think it will fit with a differant hood but it will be tight
but different cams and intake manifold.
and no alternator, but who needs one of thoes?
1 - 19 of 19 Posts
