Jedi Master
as you can see <--- i own a 91, but i wanted to do some other things with my exhaust, like actually put a rear exit, what's needed to do this swap??? i've searched a bit but found no real answer. thanx in advance.
besides, the tank...I would have to say the mounting straps. i cant imagine ford would have actually spent the money to retool the inlet and outlet tubing on the passenger side fenderwell, i would grab all the necessary hoses and lines from the tubing at the fenderwell to the tank also.
all you need is the tank, exhaust and pump, the straps should be the same . and the fuel lines and filler hoses/vent are the same
Jedi Master
do you about how much i'll end up spending???
that depends on what you find
Full Metal
if you go junkyard, the tank will prolly be about a 50-100, pick and pull sucks 'cause they punch holes in everything to drain the fluids, so it's hard to find one there, i woud say highball it and say 200 bux for everything..
