1 - 11 of 11 Posts
I know the 94-95 are the same(i have a 94), but I my local junkyard has a 96 that was wrecked, they said they will pull it to the front for me to look at and see what I want off it
Are there alot of parts that are the same?
If so, I'll need to get down there and grab a few things.
Also, whats a few good parts to grab that I dont need now, but will in the future?
Thanks
Off the top of my head....
hood
headlights
header panel
bumper cover
block
intake system
fuel lines
cylinder heads
I'm sure there's more that I'm forgetting, but If I was you, I'd get the entire engine, or at least from the cylinder heads up.
Tail lights
Sport option
Body molding
Factory Wing
3.27 gears standard
That's all I can think of.
-Miller
Refrigerator Raider Hater
you should grab the heads, intake manifold, intake elbow, TB, intake tube, fuel rails, fuel lines (from filter to rails), Throttle cable/ cruise control cable bracket and cables, and all the vacuum lines.
ok, thanks for the ideas, the 96 he had was a v6... He then then checked again and found a 95 4.6...
hes gonna pull that one up front for me within a week...gonna see if I can buy the entire car, strip it and give it back.
The only thing I really need is the plastic molding around the bottom of the power seats and the battery compartment, but I im going to try and get as much as I can off this junker because ive done this before with my last car and saved tons of cash having spare parts handy.
If I might make a reccomendation. Wait and do that with a 96/97... All the parts everyone reccomend you get are upgrades to the 94/95 style... Having spare parts is a good thing, however you might as well make those spare parts the better option...
Sam
slayer, thanks for the advise. Although I dont have access to a 4.6 ltr 96-97 atm.
Still havnt seen what the 95 4.6 looks like yet my local auto salvage has...
On Probation
If possiable grab the front bumper, stryfoam underneath, headlights, and headlight support along with the rear bumper. I strongly recomend that you get the fuel lines from the fuel filther foward to the motor if it is a 4.6. It is also recomended to get the throttle and cruise controol cables. The reason for the parts is if you are going to do a explor motor swap the fuel lines you have foward of the filther won't work. and have been discontinued from ford dan only has 5 sets left.
blown, those parts are from the 94/95 that they are needed from?
Sam
1 - 11 of 11 Posts
