Just wondering if there is a site where I can look at the TSB's for my '97 LX without paying a fee.
Scott
I started saving all the TSB, articles, recalls, but after copying and pasting 30+ documents, I stopped because I'm running out of time and I have to get ready for work. I can zip up and email you what I have so far - trust me, you will be reading for hours if not days. That's a LOT of information involving letters, documents, images, OASIS information, etc. Everything from cam sensor to O2s to speaker buzz, to engine/tranny fluid recommendations, paint, vibration, air-bag, a/c, intake manifold, brakes, on and on and on.
Like I said, I can't give you access, but I can copy and paste these, zip them up, and email it to you. It's a lot of work, so if you're just doing this because you're curious, I think you'd be better served by trying to diagnose/repair particular symptoms/issues with your vehicle and asking for info as you require it (don't forget to SEARCH & Google).
Our public library has an automotive resources section - log in from home using your library card and get access to all of this.
Also includes repair procedures, book hours for certain repair jobs, stuff like that.
It has been very helpful over the years - you might want to see if your local library has something like that on their website.
Thank you for your generous offer, NetKeym. I will take you up on what you have created so far and PM my email addy to you. I was hoping to find the TSB's online so that I would not have to impose on anyone, however I really appreciate your helping me out.
Below is a link to the thread I started in the 3.8 forum about a real head scratcher of a problem with my car. The shop that has the car is about ready to give up & turn it back over to me.
http://forums.tccoa.com/showthread.php?t=132020
Yesterday I remembered an acquaintance who works in the bodyshop of a local Ford dealership and called him up. I was hoping that he might know of one of their technicians (mechanics to us old dogs) that may be willing to work on my car at his own house so that I can keep the repair costs down (I am an unemployed bum). Sheldon no longer works at the dealership and didn't know of a mechanic who did side work anyway. What he did suggest is that I look into the TSB's that Ford put out on the car and see if the symptoms were widespread enough to warrant a Ford TSB on the problem. So I Googled for Ford TSB and kept running into sites that I would have to subscribe to in order to read up on them. For example AllData listed over 100 TSB's but by the title of them, I wasn't sure if any applied to my problem so I was hesitant to plunk the $ down. Sheldon also suggested that I go to the dealership in person and talk to a service man in person to see if I could read through their TSB's w/o paying and also to possibly get some insight to the problem. I definitely am going to do that, but NetKeym, if you would email what you have already scanned I may find a hint or two to the issue. Thanks again.
mrs.tbirdbrain (nice handle btw), thanks for the tip. My Chilton's manual is not very specific where I think I need it to be. I will see what the local libraries have if the TSB chase doesn't pan out. And thanks again to you, also.
I want and need my car back. The 10 mpg on the old Ramcharger is getting old, and he is getting tired of being driven everyday as well.
Scott
Scott
I sent the zipped up 30 TSBs. If you check out Buckcreekbilly's link, you will see there are 105 documents total (that should give you the idea of the magnitude of this thing). I got all this info off Alldata which has diagrams, photos, letters, troubleshooting, etc. from Ford complete with part numbers and links that came of Ford's OASIS system. Good thorough info for you! I'll get you a second batch of 30-40 docs in a couple days, then there will just be one final batch and you will have them all! Oh, and you're welcome, I'm just glad I was able to help.
You all have access to Alldata from your library? I've never seen that, but it would be cool!
More TSB's
Hey Scott's Coug,
Sorry I took so long, but I just zipped you up another 30 TSB's for your 1997 LX and sent them to you. There are about 40 left and I'll send two more batches, then you'll have them all. Good luck because there is A TON of reading involved in reading all those!!! LOL
Happy Holidays!
List of TSB's!
Ok, I've got all TSB's relevant to 1995-1997 Thunderbird's now.
Here is a list if anybody needs a copy or to just view one:
00B33 Recall - Airbag Deactivation Shunt Replacement.doc
97M91 Campaign - Intake Manifold Replacement.doc
05N04 Campaign - Intake Manifold Extended Warranty Coverage.doc
TSB 96-17-9 PCM - MIL ON, DTCs P0300 thru P0308 Stored.doc
TSB 96-20-1 Paint - Codes & Colors, Cross Reference.doc
TSB 96-20-7 AC O-Ring - Availibility & Applications.doc
TSB 96-20-8 AC - New O-Ring Applications.doc
TSB 96-22-1 Windshield, Interior Glass - Fog, Film.doc
TSB 96-22-5 Mass Air Flow Sensor - Assembly Replacement.doc
TSB 96-24-6 Electrical Diode - Identification & Replacement.doc
TSB 96-24-9 AT Torque Converter - Leak Test Procedure.doc
TSB 96-25-17 Torque Converter Clutch - Vibration/Shudder
TSB 96-26-12 Torque Converter - Cleaning & Replacement.doc
TSB 97-8-11 Rear Axle - Whining/Howling Noise
TSB 97-9-5 Engine - Hard Starting/Long Crank/Stalling
TSB 97-10-5 AC - Insufficient Cooling, Compressor Failure.doc
TSB 97-10-6 AT - AODE, 4R70W Shudder, Vibration in 3rd,4th Gear.doc
TSB 97-11-11 AT - AODE, 4R70W Erratic, Prolonged 1-2 Shift.doc
TSB 97-12-1 Moonroof - Wind Noise
TSB 97-13-10 Remote Keyless Entry - Diagnostic Tips.doc
TSB 97-15-5 AC - Refridgerant Oil Refill Capacity.doc
TSB 97-16-7 A/T - AODE/4R70W Service Tips
TSB 97-17-16 AT Oil Cooler - AODE, 4R70W Leaks.doc
TSB 97-17-2 Rear View Mirror - Reattachment.doc
TSB 97-18-4 Radio - AM Band Static While Driving.doc
TSB 97-19-11 Heater Core - On Car Pressure Test For Warranty Claim.doc
TSB 97-19-12 AC Pressure Switches - Obsolete Parts Return.doc
TSB 97-19-4 Brake and Rotor - Service Tips.doc
TSB 97-22-1 EGR DPFE Sensor - Voltage Range Revision.doc
TSB 97-24-13 Remote Keyless Entry - Diagnostic Service Tips.doc
TSB 97-25-5 Blower Motor - Chirping, Squeaking.doc
TSB 97-3-5 AC - R134A Tracer Dye & 3 O-Ring Spring Couplers.doc
TSB 97-5-3 Tires - Vibration While Driving at Highway Speeds.doc
TSB 97-8-8 EATC - Service Tips.doc
TSB 97-9-8 PCM - Programming Tips.doc
TSB 98-12-5 AC Filtering Refridgerant After Compressor.doc
TSB 98-17-1 Seat Leather Cleaning.doc
TSB 98-18-14 Air Conditioning Dripping On Floor.doc
TSB 98-18-2 Paint For After Warranty, Repairs.doc
TSB 98-2-7 Air Conditioning - Musty, Mildew Type Odors.doc
TSB 98-20-10 Exhaust System Buzzing, Rattling.doc
TSB 98-21-6 Steering Wheel - Nibble Felt On Rough Surfaces.doc
TSB 98-23-10 Lean Drivability Symptoms.doc
TSB 98-23-12 AT - Multiple DTC's Stored Diagnosis.doc
TSB 98-24-6 Electrical - New Terminal Grease Released For Service.doc
TSB 98-25-9 Interior Trim - Vinyl Surface Repair Tips.doc
TSB 98-26-2 Fuel - Volatility Related Driveability Concerns.doc
TSB 98-3-3 Paint - Surface Defect Removal Without Repainting.doc
TSB 98-3-4 MAF Sensor - MIL ON, DTC's P0172, P0175 Set.doc
TSB 98-5A-11 Brakes - Elimination Of Sanding Rotors & Drums.doc
TSB 98-5A-13 Brakes - New Silicone Compound/Grease
TSB 98-5A-18 Brake - Roughness During Application.doc
TSB 98-5A-4 Lug Nuts - Proper Installation, Torqueing.doc
TSB 98-5A-5 Hub-Mount Brake Motor Machining Equipment.doc
TSB 98-5A-6 Antilock Brakes - Cycling On Rough Roads
TSB 98-7-4 Engine - New Gasket Sealer.doc
TSB 98-8-7 AODE,4R70W Shudder, Vibration Over 35 mph.doc
TSB 98-88-14 Air Conditioning Dripping On Floor.doc
TSB 98-9-2 Door Latch Handle - Stuck Open Or Closed.doc
TSB 98-9-9 Fuel Injector Non Warranty Reimbursement Testing.doc
TSB 98-10-8 A/T - AODE/4R70W Revised Forward Clutch Service Tip
TSB 99-11-1 Comprehensive Noise, Vibration, Harshness Procedure.doc
TSB 99-12-10 Paint - Rough Texture.doc
TSB 99-15-2 AT - Transmission Flush & Fill Tool Available.doc
TSB 99-19-4 Brakes - Vibration, Inspection Service Tips.doc
TSB 99-19-6 AC - Identification of Non-Approved Refrigerants.doc
TSB 99-2-3 Windshield - Water Leaks.doc
TSB 99-24-2 Locks - Lock Service Packages Available.doc
TSB 99-26-9 Fuel Economy - Customer Expectation vs Vehicle Usage.doc
TSB 99-4-3 PCM - Reprogramming Out Of Vehicle.doc
TSB 99-5-3 AT - Cold Fluid Level Checking.doc
TSB 99-8-15 Interior Door Trim Panel - Replacement Tip.doc
TSB 99-8-16 Motor Oil - Viscosity Grade Recommendation.doc
TSB 99-9-6 AT - 4R70W (Reman) Delayed or No 2-3 Upshift.doc
TSB 00-23-10 AT - In Line Fluid Filter Kit.doc
TSB 01-10-12 Wire Harness - Terminal Repair Kit.doc
TSB 01-21-6 Hood Lamp Switch - Revised
TSB 01-23-6 Engine Coolant - Propylene Glycol Recommendations.doc
TSB 01-24-6 Engine - Oil System Priming Procedures.doc
TSB 01-7-3 Fuel Pump - Whine Heard Through Radio Speakers.doc
TSB 01-9-7 Emissions, Engine Controls - Driveability Diagnosis.doc
TSB 02-1-4 Engine Head Gasket - Approved Replacement Procedures.doc
TSB 02-1-6 Wheels, Tires - Road Force Measurement Equipment.doc
TSB 02-1-9 Engine Oil - Oil Recommendations, Applications.doc
TSB 02-11-4 Aluminum Engine - New Cleaners, Service Tips.doc
TSB 02-16-4 Audio System - Whining, Buzzing Noise From Speakers.doc
TSB 02-17-6 AT - Inadvertent Shift Interlock Diabling.doc
TSB 02-2-2 Intake Manifold - Cross-Over Channel Coolant Seepage.doc
TSB 02-2-3 Engine - Aluminum Block, Head Maching.doc
TSB 02-20-8 AC System - Diagnosis and Service Tips.doc
TSB 02-21-13 Engine - Cylinder Head Straightedge Surface Check.doc
TSB 02-22-1 Engine Controls - Engine Surge, Rolling Idle, DTC's Set.doc
TSB 03-14-8 AT - Cooler Flushing Service Tips.doc
TSB 03-18-1 Keyless Entry System - Service Tips.doc
TSB 03-26-1 AT - 4R70W Needle Bearing, Race Kit Service Tip.doc
TSB 04-24-14 Engine Controls - General PCM Programming Procedures.doc
TSB 06-14-4 AT - Mercon V ATF Usage.doc
TSB 06-06-26-1 M/T - Mercon(R) V ATF Usage Information
TSB 07-1-7 Steering - Mercon V(R) Fluid Usage.doc
TSB 07-21-2 Engine - Spark Plug Hole Thread Repair Procedure.doc
As you can see, I have them all saved in Word format. There are 102 of them, if you need one I don't have, let me know and I'll get it for you.
Happy Holidays!
