I took my motor out a while ago... and now I can't remember where this part goes?? :tongue::confused:
By the flywheel???
That gives me a headache just looking at it. Does that mean I've taken it on and off too many times?
It bolts to the transmission at the very bottom. It's the access/cover plate for the TC nuts.
Thats riiiiiight.... Thanks
Then I can put it on at the very end right? After the motor is bolted up to the tranny?
Yes Sir
Gracias.
You guys have any tips on getting the motor to align to the tranny, exhaust and motor mounts all at the same time?
Gracias.
A pry bar and a lot of swearing!!
usually what I do is jack the trans up as high as I can and get it lined up with the engine.
Then install a couple of trany bolts.
After that I line up the mounts and then worry about exhaust.
Now all that's left is installing all of the bolts, wiring and any necessary bandages.
