1 - 14 of 14 Posts
Can anyone help me out with this wire?
The colour didn't quite come out properly in the picture; it's a yellow wire with a white stripe. The car is a 94 Thunderbird LX with a 3.8L.
It doesn't seem to effect the running of the car, but it's driving me nuts to see the wire there and not connected to anything.
Sending unit in the back of the motor on the water pipe.It's right below your hand
Agreed, though I doubt that he has that sensor on his '90, in which case it gets left disconnected.
-Rod
I actually swapped the engine from my 90 Cougar into the 94. I picked up the 94 for $200 as it had a dead engine (spun bearings). I'm assuming that this wire was for running the electric fan. I don't like electric fans, so I used my old clutch fan setup from the 90! :D
Thanks for the replies.
Oops, I thought I saw a "90" on his profile.
That wire has nothing at all to do with running the electric cooling fan. It's used for the auto climate system.
-Rod
Cool. It's good to know these things. The engine swap was a pain in the butt, just because of the crappy 3.8L engine mounts. I'd like to string up the engineer who designed them.
So if I do not have auto climate control, this wire does not get hooked up? I just did some fiddling at the back of my motor, and this wire showed up. I have a 96 4.6 without auto climate. This wire is driving me crazy...
It senses the temperature of the coolant and prevents the blower motor from operating when the coolant isn't hot enough and you want the heater to work. This stops it from blowing cold air when you want hot. If you don't have it plugged in or don't have the sensor, the blower motor will run no matter what. No big deal.
i'm glad i found a 93 cougar donor for my 93 t-bird!
so many people said its gonna take weeks to get it swapped......took a day and a half 1st day set the motor in and hooked up the trans and motor mounts, 2nd day all the wires found their home.
Wow, I have wondered for months what that was there for. I swapped a 2004 3.9L out of a mustang into my 96 and could not for the life of me remember where the hell that wire was attached before I pulled the motor. My wife was laughing at me telling me I shouldn't have been drinking. Well HAH, who's laughing now? Cool I can cut it out now. Thanks guys!
1 - 14 of 14 Posts
