1 - 12 of 12 Posts
Baddest N/A NPI in Canada
The only head I know that has a part# stamped on it is the SVO head. That part# is by the exhaust port.
The heads have a casting# which is above the camshafts!
No, you would need to remove the valve cover to see the camshafts.
There is also a Casting# by the exhaust port! I doubt you can see this one as well.
Boom.
DMcBrideBoston said:
Where on the heads is the part #, the heads are on the engine so I don't know where to look.
I wanna go out on my break and check the #'s out.
Any fast help would be great!
Thanks
Any particular reason why you need to see the casting number? Being a '95 you have F4AE heads. Shouldn't be too much of a mystery there.
I guess they COULD have used a 96+ engine and swapped over the intakes and such.
you can see the casting number on the rear side of either cylinder head . I looked up from underneath with a flashlight . your are looking for a 4 or 5 . I too had my motor replaced with a unknown. I also purchased a 96 motor out of the junkyard for a spare and parts. I could read the casting number very clearly with spare engine laying out of the car. turns out the unknown was a 94 motor with the 4 heads.
1 - 12 of 12 Posts
