I'm not getting any voltage to my A/C clutch. I jumped the plug to the low pressure switch on top of the drier and still no voltage to the clutch. If I apply 12V directly to the clutch, the A/C works fine. I can't find any fuses for the A/C in the box under the dash or in the engine compartment. Haynes shows a WOT cutout in it's electrical diagram, I don't see it so far.
Steve
Its on the passenger side of the engine compartment, close to the firewall and accumulator. At least thats where it was on my '92 LS. Its just a relay and was pretty cheap if I remember correctly.
-Rob
Thanks, I found the problem. I wasn't even getting juice to the low pressure switch, which comes before the WOT cutout in the electrical diagram in Chilton's (better diagram in this case than Hayne). Turns out a wire was shorted out and melted in the harness which went to the low pressure switch. I spliced in a new piece of wire. Also turns out that there is a fuse for the A/C clutch in the fuse box under the dash, which isn't labeled as such on the fusebox label. It also covers a bunch of options which I don't have, so I never noticed anything else not working, it was labeled "run".
Bad *** man :)
