For a little while now I have been monitoring my cars oil consumption. I have to add 1-2quarts Every two weeks! Now when I park it in the garage I throw an old table cloth under the car to see if it leaks... No leak... the only answers I could get from my mechanic was "It's a ford". So my question to you is.. Where the hell is my oil going!?:2huh:
1) How many miles?
2) what kind of oil are you using?
3) Well I'd say out the tail pipe!
1) 81.000 Thousand Miles
2) I use 10w40 motor oil
3) And no I don't get smoke from the tail pipe
O and it's a '95 icase you wanted to know
If you can't find any obvious things, oil on the ground, and such, I'd bet you need valve seals, a common problem on '95's. Mine goes through about 2 quarts a month.
what about the oil pressure sender, if it was leaking it would probally do most of its leaking while you are driving. just a thought ??
