I'm putting 355's in my 91 sport,the speedo gear calculator at sccoa site says I need a 22 tooth gear but I only see them as large as 21.My tires are 235/60/15.If I put a 21 in would my speedo be off by a great deal?Thanks
I know you need the orange gear, not sure how many teeth it has though.
Moving to Drive Train.
With the 21 tooth (purple) gear, your speedometer readings will be off by 4.39% if I've done my math correctly.
So, for instance, at 60 MPH, your speedometer would read 62 MPH.
You can get the gears at your local Ford dealership.
-Rod
Thanks guys,I'll check out ford and throw those gears in.I'm looking forwad to the extra get up and go.
My '93 AOD had a 7 tooth output shaft from the factory. Yours may have an 8 tooth or a 7 tooth. Kinda hard to count with the tailshaft on.
