1 - 11 of 11 Posts
I have been looking all over for the 22C plugs that are recommended, along with the 180* thermostat, but no one sells them! Then I asked for plugs two heat ranges colder than stock and they all say, "Those are the coldest we have"
I'm really frustrated with these parts stores. They never have anything I need. I can't get banjo bolts from them, either. Looks like I'll have to wait til monday to get them from the stealership.
Dan Newman at fordpartshq.com has them.
Call him up and order some stuff to support our vendors.
AGSF32CF6 is stock heat range
AWSF22C one range colder
AWSF12C two ranges colder.
AWSFA 12C
:D
Also, Ford was a fine wire plat plug in a 22 heat reange. AWSF22FS
joseph
I agree with Justin, call Dan Newman. He'll get the plugs to your door for way less than you would pay at the stealership. Just received my Lightning Iridiums and Ford racing wires from Dan the other week. He's a great guy to buy from.
B
so i have a 180 stat what type of colder plugs could or should be installed ??
AWSF22C or Autolite 103.
joseph
joseph
Do you need a chip for those to run properly?
use the OE 32 heat range if you dont have a chip..The purpose of the chip is to take advantage of the full timing advance and 180* tstat to run cooler.
joseph
joseph thanks alot man im going to go get the plugs tomorow thanks again
rigel
1 - 11 of 11 Posts
