1 - 14 of 14 Posts
Anyone had any luck finding a replacement wheel stud in a longer length? Looking for some for my front hubs.
Thanks in advance, Chris
Like Titles Matter
I used ARP studs, they came from either Summit or Jegs.
i used ARP studs, they came from Summit
But you're running mustang hubs up front right? I have the hub swapped rears, and MN12 fronts. SVT bird wheels in front (17x7), and Mustang R58 (17x9) rears.
whats the knurl size of the ARP 3" longstuds with the quickstart? i had the info, ive got them on the car already but need to replace one side. need new studs to go along with it. and i cant remember what ones i ordered the last time.
nevermind, figured it out. found the reciept from summit when i got them
Brand ARP
Manufacturer's Part Number 100-7703
Part Type Wheel Studs
Product Line ARP Wheel Studs
Summit Racing Part Number ARP-100-7703
UPC 672036000417
Wheel Stud Style Press-in
Thread Size 1/2-20 RH in.
Knurl Diameter (in.) 0.625 in.
Underhead Length (in) 3.500 in.
Knurl Length (in) 0.400 in.
Quick-Start Nose Yes
Quantity Sold as a set of 5.
Notes Fits Ford rear disc brake and Chrysler front brake applications.
future search refrence 3-1/2" 3.5" wheel stud lug stud knurl size arp wheel studs
Those are part numbers for a mustang hub, or thunderbird hub lug hole.
what? Are you drinking? That didn't answer my question Keith
I said mustang but u have to drill the hub to make em fit.
And no not drunk...yet
Well crap, you would think they would have a direct replacement for mustangs.
Hi
Why do you need longer studs?
I use Moroso 3" studs, rears. 46185 wheel studs.(1/2x20)
Kept the stock Mustang fronts. I use 1" lug nuts!
:cool:
i used the arp as well in my mustang hubs, redrilled out the wholes with the correct bit which i believe is 15.75mm. you can order the bit which is about 30 or 40 bucks. they don't seem to exist for a 1/2 inch drill chuck so I turned mine down in a lathe.
David
1 - 14 of 14 Posts
