Baddest N/A NPI in Canada
Ok, I am looking for a set of cams for the TBird new motor. I am wondering if I should go with the Comp 268's or Crower? If I go with Crower any suggestions for what I should consider. The heads will be P&P SVOs. The goal for the engine is to be 11.5:1 compression.
On Probation
It depends on how high you want to rev the engingine and a bunch of other factors like gears, intake, tire size, converter stall, intended purpose so forth and so on. I would not go with no more than .550 lift even with aftermarket springs If you want any spring life or valvetrain life. I think that crower dose a better job than comp cams.
Refrigerator Raider Hater
alot of guys on modular depot like VT cams. Similar power gains as comp but no PTV issues. I know Big Al has some fairly aggressive crower cams he is looking to sell...
High-Mileage 4.6L Thrasher
You'll have a tough time getting to 11.5:1 CR.Flat-top pistons only yeild 11:1 with an SVO head..
JL
If it doesn't get to 11.5:1, I am not to worried. JL, would you recommend the Crower Springs over the Comp ones?
I plan on running about a 3500 stall TC, 4.10's, P&P SVO intake and a few things.
IMO,Crower makes a better product.
JL
