1 - 11 of 11 Posts
Neither will work on your 95 your only options are a 02 gt intake tube thats modified or a civic tube from autozone
I plan on changing my Whole intake to a Updated 97 PI manifold! I did a little bit more searching and I think I am gonna go with this setup.
Accufab 70mm T/B & Plenum
C&L TrueFlow Intake Pipe
02 Mustang 80mm MAF (Blue Oval Chips)
K&N 7" Air Filter (Blue Oval Chips)
and a Custome Heat shield to put around the Air Filter to keep the Engine Heat out!
just get a mustang airbox to mount to the MAF, and the cone filter will fit in it and be shielded from the heat..
PI manifolds didn't come out until 99. If you're buying a 97 manifold from someone and they're claiming it's a PI manifold, it's probably just the NPI version with the aluminum crossover. Just thought I'd let you know.
Thats what I meant, the updated one with the aluminum crossover, I wasnt sure what year they came out, thanks for that info!
You do know you have to have the 96-97 fuel lines egr vavlve upper intake and some other misc stuff for that intake
-Matt-
1 - 11 of 11 Posts
