Which Npi intake off other than a thunderbird 4.6 will be a direct bolt on piece without needing to tap sensor holes etc.? Also, does anyone know the part number of the alternator bracket I will need for the aluminum crossover?
thank you.
I will assume you are talking about the '97 listed in your sig because there are 2 different 4.6l intakes the 94-95 variety and the 96-97 variety.
You can get an intake off a 96-97 cougar, 96-98 mustang and although the throttle body faces to the opposite side I believe the intakes are the same on the crown vic, grand marquis and town car from 96-98.
Intakes from 4.6L engines on the following cars are identical and will bolt right up:
96-00 Crown Vic
96-98 Mustang GT
96/97 T-bird/Cougar
96-00 Grand Marquis
96-00 Town Car
Anything later will be PI and will need some minor modification to work.
