The length of time of the whistling sound, is the time it takes to shift from neutral to drive, and then disappears.
Discussion Starter #2
After the car warms up, and shift into drive, I hear a very short whistling sound. Not in reverse, and not when cold. Car runs OK. Should I be alarmed?
Check for vacuum leaks. Bad IAC could also be the culprit.
