Ok I think I know what this is but maybe I am wrong, recently my car started to smoke but not all the time just if I am sitting at idle and hit the gas then I get a puff of white smoke????
Boost Happy
weswing04 said:
your valve seals are bad. typical of the 4.6L motor. just keep oil in it and you'll be fine :)
i agree with you that the valve seals go bad but you dont blow white smoke from the seals , white smoke ist oil , you burn oil from the seals , make sure and see if its white like you said or bluesh .
Jurgen
it should be a blueishness...or something to that affect...thats a typical 94-95 4.6...i think they go more then 96-98 4.6s....mine use to do that....if it idled for a while
