1 - 11 of 11 Posts
I know there might be more than one answer to this question.
Heres the needed parts.
I need to pick up some OEM quality stuff for my 94 bird.
2 steering rack elbows both return and pressure
an idler pulley and serp belt tensioner for a 94 4.6
Also if possible to buy a goodyear gatorback belt as well for the same car.
I can pay asap.
Why don't you just contact Jason..He is our resident Ford Parts guy.. :)
Right here----->>>>>FordPartsCounter
He's a good guy too..Always come through for me..
You should also check rockauto.com
I've found good quality parts for crazy cheap pricing there (Brembo rotors for closeout @ $20, Motorcraft rear shocks for $10.77 -- also closeout are my two favorite examples).
There's always a 5% off coupon you can find (search this site).
Yeah.."Rock Auto" has crazy "Rock Bottom" prices on some discontinued Motorcraft parts..
Problem I always run into is..I need a pair, and they have (1 in stock) :facepalm:
You can do what I do. I buy online at advanceautoparts.com and use the 40% off coupon.
Generally beats Rockauto on everything.
So whats the 40% code?
Rockauto's shipping prices are horrible sometimes, so I will check on amazon and save money with their free shipping. (when available)
I've had good luck with Gatorback belts on Ebay.
If you buy around $50 worth, use ES123 as the discount code and that will save you $20 - 40%
There are other codes, but that is what I've found works the best.
And yes, Amazon works well too!
And I got my Gatorback from eBay for $10 :thumbsup:
I have used www.tascaparts.com for OEM parts also. They are way cheaper than my local dealer.
I get parts from http://www.FastPartsNetwork.com sometimes. It works well when I am too tied up at work to go to the dealer. I think his prices are pretty low as well.
1 - 11 of 11 Posts
