Do you already have 15" rims your thinking of using, or do you just want to put 15's on it? :confused:
No one makes anything wider then a 7" wide wheel in a 15" dia for a 5x4.25 bolt patern that I've ever seen.
i don think a wide 15 inch rim would look good, id go at least 16's to fill up the fender gap... but whatever floats ur boat, and to answer ur question i dont know the widest
i swapped over to the mustang bolt pattern and am running a 15x8 weld pro star with 5.5" of b.s. check my website for pics. the only reason you can't run wider on the rears without sticking out more is due to the upper control arm. but if you switch to a straight axle rear end..............there's enough wheel well for at least a 10".
Dave
