Can someone tell me what the widest tire is that I can put on a 97 TBird Sport with stock wheels and OE tires that are 225/60/16's. Are 235/55/17's the widest while not making the speedo off too much?
Thanks
Thanks
I'm running 225/55/17 GoodYear F1 tires all around on mine..Which is almost exactly the same diameter as the 225/60/16..
IMO running more sidewall=more comfortable ride.. :)
You could run those 235/55/17 tires..
Your speedometer will read slower then your actual speed with that size though..
Which means when your speedometer says you're going 55Mph..
You might actually be going 60Mph..
