the other night, my pass side window guide (the one that sits vertically and on the back side of the door) fell down into the door... on the way down it did something to the power lock mechanism... we got the window guide fixed, but the power locking mechanism wont work properly. it still has power, and still will unlock the door IF you are holding it in the proper position. however, the little fork looking piece of metal and the circular guide that it goes into came disconnected and the actuator assembly itself is sitting in there loose. how do we reattatch the actuator assembly back to the door (we thought that the rivoted bolt on the outside of the door was busted and thus we couldnt get the part back in properly, HOWEVER that rivot holds the fork looking piece that slips around the little plastic washer. so we know thats not hte problem) i, for now have disconnected that actuator temporarily, but id like to get the power locks working on that side again.... thanks for the info
Discussion Starter · #3 ·
we kind of did that..... we had an 89 xr7 that we looked at, but couldnt tell in his car how its hooked in... so i doubt that opening the drivers side would help, however i do plan on opening that side to put a washer on the bolt that broke through the metal (not because of rust, because the metal tab is weak) to prevent the otehr track from falling in
