1 - 12 of 12 Posts
Okay, so check this out... my parents bought a beater 94 3.8 Tbird and it doesnt run to well... My dads old school so to chech if it need a tune up he sprayed under the hood while the engine was running. Okay so for the wierd part, It made it run smooth and evern made the check engine light go off. Another crazy thing is fan only works when it not plugged in... And when its not plugged in it wont stop. This car is just Crazy. Anybody ever have anything of this sort happen before.
so when the fan gets no power it'll run all day, and when it has power it won't run??
Yeah... I meant to say when the tstat isnt plugged in the fan will work..... when the tstat is plugged in it won't...
You are incorrect in what you are saying. The thermostat is inline with the upper radiator hose. It has no wires attached to it. What you are referring to is the coolant temp sensor, and the fact that the fan turns on when you unplug the sensor is a good thing. That is supposed to happen as it is a fail-safe for the PCM when it no longer knows what temperature the coolant is.
If the car runs like crap, there are a couple things I would do first. Start with new plugs and wires. Change the PCV valve, oil, oil filter, air filter, fuel filter, and vacuum lines. Then clean the MAF sensor and reset the computer. With these steps (which aren't too expensive) you will have covered all the bases. Make sure you verify the timing is right too unless it doesn't have a distributor.
Don't forget the SeaFoam!
It sounds like his dad sprayed carb cleaner (or something of that nature) to check for vacuum leaks, and apparently found at least one (when the idle smoothed out). I'd start with fixing said vacuum leak(s) first.
-Rod
No he sprayed it with the hose... Its an old school way to check for bad spark plug wires... And you are absolutely correct... I did mean the coolant temp sensor sorry for my ignorence... Well anyways thanks for the info I didnt know that it was a safety effort to keep the engine cool. And BTW the first thing I did was clean the MAF... made it run 30% better.
Maybe you have some a bad electrical ground and the water provided an alternate path. I think there are ground straps from the lower right and left of the engine block that go to the frame rails on each side. You should make sure they are clean, bright, and tight. (With battery disconnected first.) There may also be one on the back of the driver's side head. The battery cables are probably worth replacing too, but they are kind of a pain to do. You can run new ones without removing the old ones entirely, though.
Trunk Monkey works for SeaFoam,...........unnofficially!
good luck w/ the beater man, I'm with S Mazza, and I do electronics for a living & sounds like a short somewhere. And unfortunately when you get it from someone and don't know the history, anything is possible. Good Luck
Well hey everyone thanks for your help.... unfortunately before I could check into anything the car lost the bottom hose and blew a head gasket. For having a blown head gasket thing still runs strong if it wasnt for the cooant in the oil I wouldve guess it was an intake gasket!
1 - 12 of 12 Posts
