1 - 16 of 16 Posts
i need to replace my heads cause the passenger head gasket blew and the head ended up cracking?whats the best thing i should do?i find a lot of people selling sc heads i cant find any from an lx if its not possible to use sc heads what should i do?
I don't believe the SC heads will work on a non SC engine. I would check with local parts stores or machine shops for another haed.
You can use them. The SC head is beefier.
I'm glad to know this as well. I have read else where that said the SC heads wouldn't work:crazy:
Than you for setting me straight Joe.
I bet they are beefier. I wasn't worried about the 93 3.8 I bought new blowing up, because I knew the superchargerd version was holding up OK. Boy was I wrong.
Bob
What makes the SC heads better than the NA heads in terms of headgasket sealing is the location and number of coolant passages near the combustion chambers.
This is a 89-95 singleport NA head:
This is a 99+ splitport head (the coolant passage design is nearly identical to SC and 96-98 NA heads):
Notice the difference?
-Rod
NiteFire said:
so would the splitport heads fit on a 97 3.8?
yes, but you'll also have to change intakes, throttle body, throttle linkage, egr tube, wiring harnesses, vacuum lines, and ALL kinds of other things.
99+ Heads will work but is about a $1200 conversion, and you must find/make custom Return Fuel Rail.
edited for correct information -Thomas
1lowbird said:
yeah that head has been deckt a bid A
:confused: :confused:
As both Thomas and bowez said, it can certainly be done. Actually, 96-97 3.8L MN12's are the easiest to do the splitport swap in IMHO, since they already have DIS. Adding DIS to my 94 LX wasn't much fun.
-Rod
-Rod
Though, SplitPortBird has shown us that with a custom EGR tube, (or obviously, deleting EGR, which was already known) the split-port swap can be done with a distributor
True. I'm just a fan of the better tunability associated with DIS over TFI.
-Rod
-Rod
I feel the same way. I want to switch over to DIS with an EEC-V computer so I can use an X-Cal2
1 - 16 of 16 Posts
