1 - 12 of 12 Posts
what are my rear speakers? do i have a factory amp? 94 lx. i have a set of 6by9's that i had in my jeep with a box & amp... can i make these speakers fit in the rear? i took the panel off & they dont look like 6by8's...
bust out the Xacto, they will fit....honestly though...some round speakers will give a better overall sound....
dremel tool works great! you basically cram the speaker between the plastic sail and metal frame. if you want to keep it simple, just get a couple pairs of 5x7's (6x8's are basically the same thing)
Discussion Starter · #11 ·
well ijus put the 6by9's in 2day wit a 400 watt amp... it sounds GREAT!!!!! but it sounds like crap on the outside.... what can i do to not hear it on the outside??? inside it thumps nicely, but outside it theres no thump jus music..... annoying for other drivers at lights...
sound deadner, such as dynomat or fatmat anything like that. They do make inserts for this as well its a molded foam oval shaped insert takes 2 seconds to put em in.
1 - 12 of 12 Posts
