1 - 10 of 10 Posts
I BLEW OUT MY REAR DOING DOUGHNUTS THE OTHER DAY SO I GOT ONE OUT OF AN 89 COUGAR FROM THE JUNKYARD, THE ONLY DIFFERENCES I SEE IS THAT THE COUGAR HAD AN 8.8 REAR END WITH DISC BRAKES, AND MY BIRD HAD A 7.5 REAR WITH DRUM BRAKES. WILL THESE DIFFERENTIALS MATCH UP WHEN I GO TO SWAP THEM??
SO, HAVE YOU DONE THIS BEFORE, OR HAVE YOU JUST HEARD THAT THEY BOLT RIGHT UP?
Many of us here have replaced/swapped centersections (pumpkins) quite a few times. As rancher said, it's a bolt in.
-Rod
GOOD NEWS, THE 8.8 WENT IN WITH NO TROUBLE!!! WHAT ARE THE DIFFERENCES BETWEEN THE 7.5 AND 8.8 REAR END? WHAT DO THE NUMBERS ACTUALLY MEAN?
Just one thing dude, turn the caps lock off, please.
7.5 = 7.5" ring gear
8.8 = 8.8" ring gear
-Rod
Also, the 8.8" will handle quite a bit more torque than the 7.5" will.
But you have already tested the TQ limits of the 7.5"!!!!!!
68COUGAR
Both 7.5" and 8.8" ring gear varieties are equipped with 28-spline axles, thus a direct fit. 7.5" is worthless for performance use. A stock 5.0 175 horse engine will generally destroy this assembly with little effort. 8.8" is an awesome piece, it will last you through a lot of abuse. The axles can be easily recognized by the inspection covers. The 7.5 has only two straight sides, top and bottom, the 8.8 is basically a square with rounded corners. Unless you have a posi 3.55 gears are the max you should have on open rear.
1 - 10 of 10 Posts
