will not start till CE light flashes. if you try to start it before check engine light flashes it just cranks. can hear fuel pump runing. now that it's got cold you have to wait ten minutes to get it to start. anyone have this problem?? how did you fix it? IT'S A 97 COUGAR WITH A 4.6
When it won't start, is the CE light on or off when the key is in run but not started/running?
If the light is off, do you also hear your cooling/radiator fan running?
This happened to me. It ended up being the wires to the DPFE melted to the EGR tube and whenever they touched it would act this way. It took me forever to track it down. I had the SES light OFF when in key on engien not running, fuel pump running and cooling fan running.
