Offset: 40
Centerbore: 73.1
PCD: 100/108
Holes: 10
I've seen some nice chrome overhere but wanne make sure if they will fitt.
Thanks in advance!
Robert
suggested width
I've seen that the most of us have a set up of 245/45/18 but i don't like such a width. Is a 225/45 or 235/45 an option? Someone with any tires like these?
Lots of people are using 245/45/18 because the size is readily available, the width is good for our cars, and the overall diameter is almost identical to the originals. 225/45 or 235/45 would be shorter than the original tires, by around 1" and 1/2" respectively. 235/45 wouldn't be bad, especially on the 7.5" wheels, but I wouldn't suggest the 225/45/18 ... that size is made for a smaller, lighter car.
If the car is stock ride height or close to it, you could also consider 235/50/18. This is a fairly common size, will fit nicely on 7.5" wheels, and will actually be a bit taller than the stock tires, which helps to fill up the huge fender openings our cars have.
cheers
Ed N.
I don't think i'll go for the 235/50 because mine is lowered 2" and it'll look fine now and i think even with a 235/45. Thanks Ed N!
accomodation
Btw, how hard is it to find an accomodation in Toronto? I am planning for a two month course/education and maybe this will be in Toronto...
Lots of hotels, especially around the airport, which is just west of Toronto. I'm less than half an hour from that area, shoot me a message if are going to be in town.
cheers
Ed N.
I'm looking for a more cheap accomodation; staying in a hotel for two months is to expensive. Ed, shoot me your contact info if you want!
regards,
Robert
