Yes it is a direct bolt on !! Are you planning other mods in the Future :confused:
This plenum combo will yield very little HP & Torque with your current mods
in your Sig.
thunderchicken17 said:
it will be a exact fit right same cable hook up bolt holes right?
Wrong answer.
No, this is not a direct bolt-on.
You will have to find a way to hook up the vaccum line for your brakes, which is not hard.
Look to the right side of your current plenum. See the black vaccum line running from it? The Mustang uses hydra-boost brakes, so that spot is not tapped on any Mustang plenum.
Unless you are looking for the chrome look, get a used T-Bird plenum, hone it out with a dremmel and spend $200 on that throttle body. You won't get any gains, maybe some increased throttle response, but you'll save $250.
