1 - 20 of 46 Posts
My personal opinion, with $98, I could switch to Mercon V, and add a trans. cooler. That would probably take care of the shudder on it's own. If it's too far gone, I would think that no matter what, if the TC is shot, it's shot, and nothing will fix it short of replacing the TC. You could prob. even get a Mark VIII flexplate/converter for close to that if you look, and that is even better. Just my opinion tho... I would save for a new trans before buying that. I don't like band-aids.
Jay
What they said ^ :)
-Dave
It looks like a $100 delay box to me. Just something else to get screwed up and cause problems. I'm sure a tuner can do anything that box does. By no means does it improve the stock components it just delays lockup. Try this it works on all pre 98 valvebodies.
Alan
Dirtydog, you never cease to amaze us all, I have learned so much from your posts and e-mails.
Thanks for teaching us all your secrets!
-Dave
The reason I asked is I have switched to mercon V, and put in a large cooler. It stopped the shudder for about 3,000 miles. It is a very light shudder, just as it goes into 3rd gear under very light throttle. Under heavy throttle, or once it is locked, the TC won't shudder. If I manual shift it and get the rpm's up before lockup, it will not shutter.
The transmission works fine. It's just the TC shudder, and low rpm trans shift points under light throttle.
It acts like it tries to lock up too early without enough lockup force. That is why I wondered if you could change the lockup rpm's and shorten the time it takes to engage the lockup, if it would help. I hoped it might keep me from having to drop the trans just yet.
The car only has 81,000 miles, which I know is about the life of a TC in a 95. I drive it easy, and don't race, or spin the tires. I very seldom even have the throttle to the floor.
The truth be told, I want it to last a year or two more, with as little money and effort as possible. I would gladly spend $100.00 and drop the pan to give me a couple of years more use.
Exact same problem I had, do the valve body plate mod above or the whole J-Mod!
It will be gone!
It will not cure a bad TC though, replacement is the only total cure.
I have not replaced my TC yet and since I did the mod I am VERY pleased with my 2-3 shift.
-Dave
BTW: it wont cost $100 bucks either!
Fry Rice Specialist
even i jmodded my tranny and put on marauder tc still have low speed shudder until sct tune flash then shudder is gone.
There are two things that will fix TC shudder:
Mercon V fluid swap/trans cooler.
TC swap (advised only to be done with cooler and Mercon V as above).
A chip can help maximize live of the TC (esp in 94-5s) but all in all it boils down to the above.
If you have the early design lockup piston( in the converter) nothing will fix it except a new converter. They just weren't strong enough to work. Don't forget about the other variables. Bad plugs, wires or a faulty egr can cause a shudder feeling and ruin the converter clutch over time.
The 99 up valvebody is the only way I know of to get a really good lockup flow. The 98's are better than the drilling I posted, but that drilling is a 30-40% improvement over stock. It's pretty easy to tell if that modification will help. If it won't help the holes are already bigger than what you are drilling them. If you leave the cotter pin out of hole C you will get a very aggressive heavy throttle unlock. I personally like that, but grandpa doesn't.
Alan
On Probation
garbage run away fast. I would do the J mod and install A large transmission cooler. I also recomend changing the fluid every 25000 miles. A custom programed chip will also help from sct.
you can have your TC lock up schedule changed with a chip.
also, I have a question about this exact topic(mostly for Alan)
I have a new 98 tranny(slightly used). it has a JMOD, and some other goodies.
I also installed a 1300 mile old Mach 1 TC.
I completely flushed all the lines, and cooler. COMPLETELY!
mercon V, Hayden 26k cooler, Mach 1 TC, and new TCC solenoid, with this tranny.
here's my deal:
my old 94 tranny had the exact problem since I owned it, and after JMOD/Mercon V/cooler added in.
the TC locks way too early. it shifts through 1-2-3 just fine, but as early as 30 mph, the TC locks up, drawing the RPMS way down. It feels exactly like driving a manual tranny at 30 mph, and you slip it into 4th gear. The motor bogs, unless you kick it down into second, or tap the brake pedal slightly to unlock the TC.
I am considering having my ECU reflashed, or buying a chip with a custom lock-up schedule. My 97 had this exact problem severely, so our chip now locks the TC at 42 mph, instead of the FACTORY-SET 34 mph.
anayone have thoughts on this? it happens with a cold, or warm tranny...almost 90% of the time. if you drive it like a hot-rod(more throttle around town) you never see it. But if you are in traffic, or on a 30mph steet, it drops the rpms in 3rd(O/D off) down to 1100, which barely moves the car.
This ISNT the notorious shudder. But it does suck! I was looking more forward to having that problem go away with my new tranny, than I was having it be a "better" tranny than my 94. I'm bummed.
:2huh: :2huh: :2huh: :2huh:
Reflashing the pcm is the only way you're going to correct that. The transmission doesn't know when to do what so it lets the computer tell it what to do. I think it's called marriage. :p
Alan
Thats actually good news Alan. Thanks(for the 400th time)
I'll probably get my chip, and have a few different things done.
in your opinion, what is the highest MPH you would consider "safe" for a TC to stay unlocked, before it builds too much heat?
My buddy's chip keeps the TC unlocked until 52 mph... he does alot of around town driving, and his TC lock-up was alot like mine. He got so sick of it, he had his chip burned to "slip" longer.
Thanks
The bogging got a lot better with 3.73s - the car will shift into 4th and lockup the TC around 30mph, but the extra gear really makes the car wake up. It also eliminated downshifting on the highway... I just slowly lean on the pedal and the MPH climbs up nicely.
Ditto here. 3.73's prevent you from running those low rpm's and will stop that problem. He has a markVIII and I would go 4.10 on it. I just installed 3.73's in one and It didn't respond as nicely to 3.73's as my Tbird did.
Alan
And I was also surprised the 3.73s didn't really hurt the gas mileage, as long as you are driving close to the speed limit. 22-25 MPG highway isnt bad. Go 85mph and it would probably drop a bit more than it would with 3.27s, but that's expected.
This electronic board does work. I have it in a J-modded 94 mark viii tranny that I believe was rebuilt. I put in a new from ford 98 mark viii converter and the shudder started up about 800-1000 miles after install. Threw in some Dr. Tranny's shudder fix and the shudder problem went away. While I was investigating the shudder problem I read about this electronic board and found one of these on ebay for $15 so I grabbed it up (I would not have paid $100 that is redicoulous). I installed it while I was bored at work one day (remember the shudder problem was already gone) The electronic board did help the overdrive shift it seemed quicker. It also now shifts into overdrive at a higher speed. I think this would fix blackIce's problem but it is for the older wiring 4r70w's. I don't know if it would fix a shudder problem but it did help the shift schedule is what I am trying to say... This was in a 94 Mark VIII by the way...
-Joe
1 - 20 of 46 Posts
