1 - 2 of 2 Posts
I read over on Modular Dpot that you can use a Canton Windage Tray with our stock pans but you need 2 gaskets to make it work. What 2 gaskets are they talking about?
Phillip
Refrigerator Raider Hater
Direct from Canton website
When using the 4.6L/5.4L windage tray, you should install it using one gasket between the tray and oil pan. Then the tray should be sealed to the engine block using silicone sealant.
1 - 2 of 2 Posts
