(89 base bird) i'm having a problem with the passenger window, the plastic clip that holds the glass to the motorized arm is broken and i just picked up one from a junkyard. the one i picked up from the yard is metal (also came out of a bird) and doesn't look the same, anybody know if it can be used and how to take off the broken one?
It should unbolt right from the window track arm. I had the same broblem with my '89 L.S. it's a ***** at times, and yes, the metal ones will work just possibly put a little adhesive on there to make it stick better and just slide it on.....
just got back from advance auto and napa,.....they have a whole lot of clips for windows and the like over there .... HELP brand......might want to check it out to see if they have the clip you need before trying to rig up somethin.
Discussion Starter · #4 ·
..thanks
well i checked pep boys here and they told me it was a dealer part.. so i just tried the metal one with some silicone sealant. think i'll give it a couple days before i try it.
thanks guys
