The wipers on the 93 don't park all the way down. If you turn off the wipers, they just stop dead in their tracks. High and low work fine, intermit only works at one speed.
Johnny Bling Bling
joe, they worked fine for me when i gave it to you....at all speeds. i have a spare here that i can send you if you want to try it. it was good when i removed it.
Jon,
This is something that just started not too long ago. I'm thinking of pulling it out just to check the contacts.
I'm always up for packages arriving! :D
Outlaw,
I'll check that out, thanks! :)
Digging up the thread.
I have the part to change but can't find it!
Is it under the dash?!
Iron Chopz mentions in the other thread that it's up near the steering column bolted to a brace. I can't see anything that even resembles it. :(
i think i found ur problem mine seems to work only when u push it to move. if u get under there and u can hear a click. take apart the underneath of ur dash under ur steering columb, look to the left is a grey box u can see thru the metal bracing mine had one bolt holding it put ur ear to that. i think thats our interval governor
