My wipers in my 95 won't come on until I turn on my right blinker. I'm going to change the switch unless anyone else has any other ideas.
motor city poster
Multifunction switch..... replaced mine and that took care of it, but like he said ^sometiems its just the connections and they can get dirty...
I had my signal lights quit all together on my bird. I check the connection in the steering column and the connector had pulled apart just enough to start causing problems.
NOTE: If you plan on doing anything in the steering column please remove negative battery cable before as you could deflate your AIR BAGS and cause you a big headache
mercury267 said:
Great tip! Imagine the joy of getting your face sandblasted unexpectedly while just trying to repair a blinker... oooooo, I don't eben what to think about it.
I read that in the shop manual after I had my girlfriend helping me pull apart the stearing column GULP :eek:
I think you also have to wait 5 minutes to let the air bag system discharge after removing the negative battery cable.
Rob
