1 - 20 of 40 Posts
Since we are in the dead of winter, what is everyone's plans for their MN12 for Spring?
Here is my list:
What are your plans?
Is something burning?..
My list, all useful things! XD
-New Battery
-Fuel Filter
-New Tires
-Royal Purple 10w30
-J-Mod(probably kit from Rob)
-New Armrest Console Door
-Pioneer Sound System
-New Window Tint
-New Windshield
-New Ignition Actuator Pin
That's about it. It's gonna take a fortune xD
Well, my winter plans are complete. The only thing left to do is see what the results of the upgrades are.
In a nut shell the upgrades were:
  • DSS Level 5 half-shafts
  • DLF bushings and Mark VIII rear LCAs
  • Rear coil spring drag bags
  • A 10% Overdrive Harmonic balancer
  • E85 conversion including a larger fuel pump and injectors
  • New tunes for E85 and Gas
Hoping to get the 91 Cougar up and running with the 427 over the winter. Also come spring, the SC will get a Mustang bolt pattern conversion, 18x9 Saleen wheels, 93+ front spindles, and Cobra brakes front and rear.
Mickey Mouse mods.
I'm thinking of changing the intake elbow.
Blower motor (sounds like chirping crickets)
I'd like to get my cruise control working again.
Consolidate my twin 10" subwoofers into a single 12" setup.
Maybe save up for a set of cams?
That's about it. lol
projects
I'd like to finish the interior on my 89 S/C , figure out how to get the sequential blinkers to flash slower, and do the brake upgrade.
I picked up a 92 sport with a 351w, I need to paint, finish up the wiring so the guages work, and rebuild the carb.
Rebuild the engine in my 94 S/C 5 speed, (North Carolina car)
Replace the engine in my friend Randal's anny
and last but not least take my Robert Yates thunderbird to North Carolina to try to get documention if it is a Davey Allison car
Thats all
Birds in the barn.
:wavey:
Project 1: 90 T-bird Stockcar
Rebuild A 351W (stock rebuild)
Repair rear pumpkin (cover broke after axle blew)
Put C4 back in. after engine in but before pumpkin.
New upper front shock mount ( for racing shocks.)
** Mount them similar to Koni's on bottom.
need to make an upper mount. Racing shocks have loop ends.
Unding most body parts.
remount my racing nose after I open up the grill area more.
Swap to a racing gas pedal. (rule thing)
Project 2: 85 T-bird hotrod
Just about everything.
She has beensitting in a garage far too long.
Rebuild the 302. have some nice Edelbrock (carb & intake) for the top & some D2 heads.
put in my 3 + 1 trany.
upgrade the 7.5 rear to a 8.8
Bushings all around.
Brakes all around
tires all around.
I think I will start with some air in the tires. Both cars.
Project 3: 96 T-bird stockcar.
Finish roll cage
351W engine
4r trany
:zbench:
I have high hopes for what I will get done this winter but really I just want all of the maintenance up to date and to get the rear end ready for launching at the strip. If I can manage that without being sidetracked then I'll be happy.
Russell
pendejo
I'm planning to remove my Tokico coils and my premium sound cd player, and set them aside with the other parts that I don't want to sell with this car.:zwall:
Here's what I'm working on
Explorer motor swap
MT82 swap
Hand brake swap
3.27 aluminum diff w/ Torsen T2
Mark VIII lower control arms
Konis
Larger fuel pump w/ FPR
DLF (RIP) steering joint
-Bryan
Replacing the rear brake lines, and getting it to run properly so I can get it on the road and start DD'ing it again! Hopefully sooner than later
In no particular order...
  • Rebuild 4.2 with new wear items (bearings/gaskets/seals/etc)
  • Rebuild M5R2 with new bearings/blocker rings/seals/etc
  • Pull dash for paint/dye, heater core, clutch pedal install, hinges
  • Install 3.27 TL with fatty SC shafts
  • Install Eibachs and Tokico Blues
  • Pull the 2nd dead 3.8 due to HGs :rolleyes:
  • Pull the carpet out and pressure wash
  • Install new p/s rack while engine is out
  • Pressure wash engine bay
  • Install 4.2/M5R2 with necessary mods
  • Mount BFG 255/50s
  • Headlights/header panel
  • Finish black interior swap
  • Install gauge pods and 145 speedo
Not so much a 'spring list', more of a 'I better make it to the Shootout next year' list. :tongue:
Oil, oil filter, fuel filter, DOWN! :) I'm smiling now, all I gotta do is out that crap in lol
Nothing for the cars this year... working on my private pilot license. :)
1 - 20 of 40 Posts
