· Registered
Just bought a 94 cougar, and I just also bought a compustar remote start/keyless entry.
I did a search and I did not find what I am looking for, I am looking for a print out of what wires are what and where they are.
I do have a handful of relays encase I need them. Any help would be appreciated, I know some around here are installers.
· Registered
Discussion Starter · #2 ·
Well I did some google searching and came up with this....
Was honestly surprised there was nothing like this book marked.....
I am going to start possibly installing this tomorrow, will post updates. I am sure someone may find the info useful.
· Registered
Discussion Starter · #3 ·
Well I started on the install on the keyless/remote start. My brother came and finished the rest, I cut myself and had to watch the kid.
For tach signal, since you got most of the dash apart, go for the wire behind the tach.
I did not wire up my blower motor yet. That I think should be cake, I bought a 40w solder iron, the wires in the ignition switch are 10 gauge.
Someone should sticky the wiring diagrams I posted, as well as others for other years.
· Registered
yea, i pulled the Tach signal off of one of the connectors for the gauges.
white/pink wire at pin 18 of the larger connector on the back of the gauge cluster.
· Registered
Discussion Starter · #6 ·
thx sc0tty8 i was just looking for same diagram for install for my 97 tbird this helps alot
fordcds.com is down :S
im assuming 97 tbird and 97 cougars have same wiring for alarm install :p
They should be the same, glad I could help someone out!
