I
ice_nyne
·Guest
I removed the passenger door panel on my '90 bird to replace what I thought was a dead power window motor. I have since discovered that it isn't the motor at all -- I have a short somewhere in the system that doesn't allow me to control the window up/down from the passenger door as well from the passenger window switch on the driver's side (Driver's side window works perfectly, however). Does anybody have a wiring diagram for the window motor run? The relays and harnesses it goes through? I may have a faulty harness that has shorted and needs replacing, but I don't know where to begin. Anybody got any suggestions? Any help would be great. Thanks.
P.S I'm posting this thread in a couple of forums, so if you see a repeat of this, that is why. Thanks.
