5oh Transformer
Well i have swapped out the 3.8 from my 96 and now im putting in the 5.0. i have already swapped the main harness on the right side along with the computer. the problem i have currently run into a bind with my powering the harness. Where does this damn thing get its power from? Need some help please!
Zero
P.S. if anyone has done this swap please get ahold of me soon.
What exactly are you trying to power? More than likely the answer is going to be the underhood fuse box.
-Rod
I know on the 89-93 there is a plug that is behind the passanger headlight right next to the airbox that has 2 red wire's with a white stripe along with a cople of wire's for the ABS. The R?W wires were for the ECM.
Send me you're Email and I'll send you a diagram of the 96 harness so you can poke around.
5oh Transformer
[email protected] and what i need to power is the whole engine managment. i need to know what wires need switched power, on while cranking and run, and what needs to be constant power
