1 - 2 of 2 Posts
I keep blowing up DIS moudls.afer searching here and other boards, I put in a new coil (old one had a burnt terminal) and still doing it. The motor is out of a wreck that I put into a tube chassie race car. So, I've gone through and checked all the wires and grounds. I found a non-insulated ground, inthe harness going the the cam sensor, that does not terminate anywhere/ cut off.
Question 1: Any ideas on the DIS moduals?
Question 2: Where should this ground be going to?
Scott
From what I understand there are two major grounds on the supercoupes. Both of them go to the engine mounts. I dont have the stuff here to post the harness pics you need. As far as the DIS module goes. You need to purchase a QUALITY DIS module. Like from Ford not one of the cheep ones from Autozone. If I were you I would try this and if it does not work post on the SCCOA website. Some of those guys have some really good info.
1 - 2 of 2 Posts
