1 - 2 of 2 Posts
so i hit a curb going about 45 and now my t-bird won't start. I've already checked the fuel cut off in the trunk and didn't see any other obvious problem with fuel lines or sensors. I haven't had a chance to check fuel and spark because its too damn hot here (110+) and i've been busy. other then checking if im getting fuel and spark is there anything else I chould check for right off hand before sweating my a$$ off in the heat?
thanks jason
If you can, when you turn the key to the "run" position, listen for the fuel pump to run for a few seconds. That will tell you at least the inertia switch didn't get tripped. If I were you, I'd press the button on that switch anyway just to make sure that it isn't partially up. Even when they pop up, sometimes you can't tell.
Other than that, what does it do when you try to start it? Does it turn over but not fire, no turn over at all??? Expand on your "no start" please.
Jay
1 - 2 of 2 Posts
