1 - 20 of 22 Posts
What I'm currently cooking up.... ;)
Maybe it's the paranoid side of me, but I'd like to see it wrap one more bolt over around the top, and have one more gusset on the side. Otherwise I like it.
Opps.. Thanks.
It's a prototype combined rear cover brace and mount. I lathed up the bushing and made up a jig to locate the upper mount to the subframe. More pics to follow.
I guess there is no jack point with that in place of the stock rear diff mount. I like it but Id really like to see a usable jack point too.
No need if you have one of these... :)
That was the only thing I ever really found the rtlb useful for, it is the one braces that I can't tell a difference in driving if it is there or not.
Alan
Yes I use it as a jack point. I trust my welding and the attaching hardware.
I say make it bolt up over on the drivers side too since you're all up on this. Go big or go home. lol Might be overkill, but sometimes too much is just right.
It was going to be my next step when I was making these....
What will be required to install this type of brace? Bolt on or weld extra peices?
Discussion Starter #14
Bolt on.
Discussion Starter #15
Got the bushing made... Pressed. Built a jig to locate the upper frame mount..
Discussion Starter #16
Finished the upper mount.... Just need to pick up the correct hardware and put it in... Weather permitting....
I like it and want to see it bolted up. The only thing Im concerned about is the attaching hardware to the pumpkin. I think larger headed bolts or ones with integrated washers would be better. Great work. Im very interested to see the outcome. Is this going to be something you will offer for sale if it works out?
Discussion Starter #18
Yeah, I was just working up an order at Mcmaster for Grade 8 flanged bolts and flanged distorted nuts. I wasn't sure what I was going to use, and I happened to have those at home...
What kinda price range? Any chance u will make one with out the brace as I have and atomic diff cover so I need the brace but I really like the looks of it
Discussion Starter #20
I'm figuring around $350 for the combined brace/mount. I can whip up just the mount. But I would need a measurement of the space between the cover at the mount (right side) to the inside of your current brace.
1 - 20 of 22 Posts
