i bought my 84 turbo coupe a front mount inter cooler kit. i've got it installed just need to do some finish work to get it done. i still need to mount my bpv flange and install my narrow band[:mad:] in the stock clock spot. any how enough of my jaking and on with the pics.
i built the brackets that i used to mount the inter cooler
if you look you can see the VAM brace covers that i made
with factory A/C
narrow band [air/fuel] gauge made to mount in the stock clock box so it will bolt right in. also using the clocks plug for power and ground.
here is the flange and the mounting tube that i made for the bpv. the large tube is just in the pics to show how they fit together.
Discussion Starter #2
also went from this hood
back to the original hood.
looks much better this way. i like it better this way it says regular old t-bird. not a modded t-bird.
pay no attention to the grill. i've got another one that is getting modded to install
5oh Transformer
Looking good man. I always loved the 87-88 hoods on the older 83-88 frontends. How does she pull?
Zero
